Hi Dave,
I don't have a current copy of D1.5 but in D1.5:2008 (I doubt that the verbage has changed much for 2010),
Under Clause 5.21.5 Weld cleaning. it reads....
"5.21.5.1 Chipping and Brushing. Cleaning between weld passes shall be limited to hand chipping and hand wire brushing. Power chippers or grinders shall not be used during the test. Upon weld test completion and after visual inspection, the weld may be made flush by power tools as necessary to facilitate testing.(see 5.26.1.1).
5.21.5.2 Root and Fill Pass Cleaning. Root or intermediate weld bead contours shall not be modified by chipping, grinding, cutting or other means before depositing subsequent weld passes."
Just thought that I would show you where to find it in case the welders ask in the future.
Good luck with your testing.
