Dear All members
These days I am confusing about the counterboring in ASME Sec.III.
I understand that the requirement of ASME Sec.III NB-4250(c) is ruled for the length of the counterboring if the pipe or components are conterbored.
Is my understanding correct?
thanks
NB-4250 WELDING END TRANSITIONS —
MAXIMUM ENVELOPE
The welding ends of items shall provide a gradual change in thickness from the item to the
adjoining item. Any welding end transition which lies entirely within the envelope shown in Fig.
NB-4250-1 is accept- able provided:
(a) the wall thickness in the transition region is not less than the minimum wall thickness of the
adjoining pipe;
(b) sharp reentrant angles and abrupt changes in slope in the transition region are avoided.
When the included angle between any two adjoining surfaces of a taper transition is less than 150
deg., the intersection or corner (except for the weld reinforcement) shall be provided with a
radius of at least 0.05tmin; and
(c) if the weld is subject to preservice inspection,
the length of the counterbore shall be 2tmin for pipe and tmin for components and fittings, as
shown in Fig.
NB-4250-2 or Fig. NB-4250-3.
