Up Topic American Welding Society Services / Technical Standards & Publications / max convexity off fillet weld
- - By weldeng777 Date 12-17-2011 01:32
Hello
Does anyone know why D1.1 correlates the maximum convexity of a fillet weld to the width of the weld face not the leg size?
Thanks in advance
Parent - By 803056 (*****) Date 12-17-2011 14:55
Using the weld face width allows the inspector to use the same criteria for fillets with unequal leg dimensions and to check multi-pass welds where each weld bead is subject to inspection using the same criteria.
The fly in the ointment is how to actually measure the convexity. I have a tool that I designed and I am currently doing a patient seach to see if there is anything  similar. So far, nothing shows up in my searches.
- By jerrykroll (**) Date 12-20-2011 14:58 Edited 12-20-2011 15:05
G.A.L. Gage has several gages that can measure allowable convexivity - one has been around for a while - the AWS (All Purpose Weld Size gage)
The digital gage also measures throat size down to +/- .001".
