Hi:
Below is a part I’m welding and I’m looking for input/advice to see if the results can be improved in any way. I've provided the steel specs in use and the welding equipment.
Weld Process:
GMAW-P Spray
Equipment:
FANUC System R-J3Ib
FANUC M-6iB Robot
Miller Autoinvision
Tregaskiss 500 AMP Torch
Tregaskiss 401-6-62 Nozzle. 5/8 Bore, 1/8 Recess, Copper
ER 70S-6 .035 Wire
90%-10% Argon-CO2 (40CFH)
Weld Parameters:
I do not have a M60 programmer for the autoinvision so the unit came from the build house with the standard weld program #3.
Screen shot of the teach pendent:
Coordinating the travel speed of the robot in a circular motion along with the IPM of the wire feed I’d like to get some opinions and any improvements I can make. If I missed any information you need let me know.
Any input is appreciated.
