Hi Ehsan
I assume you are referring to "sour service". The issue with sour service is essentially linked to the hydrogen cracking resistance of a material. (Also other issues, but for our purposes H cracking will suffice.) For this reason, materials that are very hardenable tend to be less resistant to H cracking in service. Type 410 is martensitic, while type 430 is ferritic, so 410 can be heat treated to a higher stregnth, but care needs to be taken to make sure that it is not too hard when in sour service. NACE tells you under which conditions you can use which materials, which then will restrict you in terms of maximum strength, and post weld heat treatment requirements etc.
In your case, you need to decide what properties (from a design perspective) you need, and then see if you can get that from either of the materials you are looking at while still meeting NACE requirements. Generally the comparison will be:
Type 410: Higher strength, but potential cracking issues during welding, and generally requires PWHT.
Type 430: Lower strength results, and often very poor impact properties in thicker sections following welding.
Hope this helps.
Niekie
