Up Topic Welding Industry / General Welding Discussion / Continental
- - By empire welding (**) Date 01-04-2012 00:57
Anybody need a helper or someone to sweep their shop while I wait for a water pump for my Classic III with a TMD 27. Factory does not stock them but will build them if requested.
Parent - - By welder_Bob (**) Date 01-04-2012 01:54
You might try Bills welding repair 405-232-4799 or  http://www.weldmart.com/store/coolingparts.htm
Parent - By Tommyjoking (****) Date 01-04-2012 02:20
I reckon you are bit too skilled to push a broom in my shop...sorry you are WAY overqualified.
Parent - By empire welding (**) Date 01-04-2012 02:33
By the time I found out it would take the dealer here a week and a half to get it Bill's was closed when I called but that looks like a good part number about 3/4s down the page.  Thank you bob i will see if weld mart has one in stock.  I am lucky though the only reason I found the water pump was going bad is when I went to remove the fuel pump that is bad I grabbed the fan and it about came off in hand.  Better then going through the radiator and my back window.
- - By empire welding (**) Date 01-04-2012 02:35
That is why I love this forum everybody is always willing to help.
Parent - - By Cumminsguy71 (*****) Date 01-05-2012 04:15
You can call Stumpf's in Mascoutah, IL too, I always talk to John. I get most of my stuff from them(closer, bought my machine there).
Parent - By empire welding (**) Date 01-05-2012 07:37
Thanks man.  I did get one shipped overnight and should be here tomorrow from weld mart in texas.  But thanks for the heads up.
