I have 17 welding machines and 4 of them have been purchased at auctions. I have found that if it is working when you buy it, it will probably continue to work for you for sometime. However, every used machine I purchased did need some repair within one year of purchase, we did use them everyday though. The old machines are usually quite large and bulky and sometimes repair parts are not available anymore. In the scenario you describe I would suggest the Millermatic 250X or Lincoln Power mig 250 (or whatever the current designation is for this size machine). These industrial quality machines will last you a lifetime and the cost is about $1600.00. With the addition of a spool gun they will run GMAW, FCAW and aluminum. This should cover just about anything you will ever need. Good luck.
Mike Sherman
This is a very subjective discussion. There can be some great differences between the manufacturers of arc welding equipment.
Some get it close to right, and some do not.
That is not to say that the ones who get it wrong's machines-just the contrary. All machines from a major mfg work decently,just some work better than others.
You can never go wrong getting a machine from a major mfg-Lincoln, Miller, ESAB, L-Tec, Linde, Hobart, Thermal Arc.
Each manufacturer has it's strengths and weaknesses, but all in all the equipment is decent.
In this new age, however, repair can be a problem sometimes. Luckily enough, if you have a COMPETANT repair tech, many parts can be sourced from the open market.
Solenoids, relays, contactors, switches, pots, resistors,etc are all generic items and can be had from places like Graingers, Newark Electronics, Allied Electronics, even Radio Shak. As long as you know what you are looking for.
Circuit boards can be rebuilt by Innovat, Arc Products, National Weld Supply and others.
Other than transformers,sheet metal, and design, the major mfg do not produce much else. The rest is purchased from the same places we get our parts from.
Don't know if this helps much. If you do get into a repair situation, let me know directly. I may be able to help!!
brande
I have tentatively made a deal to trade a tractor I fixed up for a new Lincoln Powermig 200. I really wanted a Powermig 255 or Miller 251 but this machine should handle 95% of what I build now and I can use a Miller CP 250 TS at work to do really heavy stuff, should the need arise.
Thanks for all the replies, both on this page and through email.
