By 803056
Date 01-29-2012 11:52
Edited 01-29-2012 12:15
This post and the responses with regards to D1.1 would be appropriate in the section for D1.1 since many welders working with D1.1 may never or rarely visit the section dealing with ASME issues.
I agree with Niekie that a test plate welded in the vertical position, using uphill progression qualifies the WPS for all positions with regards to notch toughness (CVN). However, if production does not require welding in all positions there is no need to weld a test plate in the 3G position. Only those positions used for production welding need to be tested with CVN. In other words, if production welding is only performed in the flat and horizontal positions, test plates for those two positions need to be welded and tested with CVN testing included. However, if the fabricator has to weld in the vertical position in production or if the fabricator finds it more expedient, he can weld plates in each of the positions required for production and perform the standard test regiment plus CVN tests on the one plate welded in the vertical position. The remaining plates, welded in the other positions required for porduction, would be subjected to VT, volumetric NDT, and guided bend tests as well as reduced section tensile tests (the standard test regiment).
