Up Topic Welders and Inspectors / Welding Equipment Classifieds / 62 redface
- - By burleigh26 (**) Date 01-19-2012 21:37 Edited 01-19-2012 22:06
62 redface
   New Parts
-Battery
-altinator
-oil filter upgrade
-rheostat
-oil gauge
-temp gauge
-volt gauge
-idler upgrade
-k&n air filter
-zenith carb
-water pump
-belt
-fowler brushes
-110v plug
-stainless hood & gen shroud
- wired for cable's remote
it's in cameron, La  5000 OBO
Attachment: 62redface2.jpg (76k)
Attachment: 62redface3.jpg (0B)
Attachment: 62redface-1.jpg (86k)
Parent - - By pipehead (***) Date 01-20-2012 02:02
pics?
Parent - By burleigh26 (**) Date 01-20-2012 02:25
i cant get them to upload, but still working on it.  i can text you pics.
- By GRB (*) Date 01-21-2012 21:54
lotsa updates, what about the motor? overhauled?
- - By roundydownie (**) Date 01-24-2012 05:02
Is the machine still for sale?
Parent - - By burleigh26 (**) Date 01-24-2012 15:44 Edited 01-24-2012 16:15
Yes but I'm overhauling the motor. Last minute decision.  I should have it running again Thursday, waiting on the rings.  the motor looks good inside, it had a little blow-by but not bad.  it will be like a new motor when finished.
Attachment: 62redfacecrankshaft.jpg (0B)
Attachment: 62redfacepistons.jpg (0B)
Parent - - By roundydownie (**) Date 01-25-2012 03:53
Can I get your number?
Parent - By burleigh26 (**) Date 01-25-2012 04:41
My number 337-476-0096
Parent - - By Nitesky (**) Date 01-25-2012 04:26
What, exactly are you replacing?  Getting the crank turned?  New pistons?  Bore job?
Parent - - By burleigh26 (**) Date 01-25-2012 04:44
Putting new rings, cleaning er guts, making sure everything is working properly and nothing is wrong. Not boreing it over.
Parent - By Nitesky (**) Date 01-25-2012 04:49
It is just that your pics are of old stuff.  Crank needs turning from the looks of it.  At least one piston is scuffed badly.
Takes more than rings, lapping the valves and a gasket kit to qualify for an engine overhaul
Parent - - By DaveBoyer (*****) Date 01-25-2012 04:55
Not to be "busting Your shoes", but when honing cylinders try to get about 60 degrees angle between the hone lines on the up & down strokes. This requires a really low RPM drill to spin the hone, and a rapid up and down movement.
This condition is what the new rings wear into best.
Parent - By burleigh26 (**) Date 01-25-2012 05:04
Had it honed out doing a cross x pattern.  I have a mechanic doing this for me. The cylinder walls look perfect. The one cylinder that looks bad really isn't, it's a film. I thought it was worse myself. The crank shaft is in great shape.
