The A387,Grade 11 was qualified on plate,to AWS D1.1 in which the Spec called out. I have a new job coming up and the spec also calls out AWS D1.1, I will have 2" to 8", A335, Grade 11 pipe on this job, Both A387 and A335 being 1-1/4% chromium and 1/2% Moly. Planed filler A5.29,B2-L. With this being said, I know neither are listed base metals in D1.1. My previous question was all from AWS B2.1 out of procedure qualification based from nomenclature from 2.3.10 -2.3.12. Quote from 2.3.12 (AWS B2.1) Base Metals listed in Annex IV or listed in ASME,Section IX, shall be considered listed materials.(Listed in Both). Can I use my Qualified PQR, A387 plate procedure, Write a A335 WPS for pipe test my guys 1GR ? I'm pobably going to get told no, I should qualify A335, Grade 11, 2" pipe, just thinking out loud. Wish this Company had a true weld engineer. I've wrote alot of procedures and had them approved from some big names in the Power Generation Ind. From C-276 and on, some just are tough for me, I allways think I'm doing it wrong. I hope this shed's more light, Probaly will need a copy of B.2 to make since
