Joey,
First comment. As an American, you think in inches, not millimeters. 0.5 millimeters is just a little bit more than 1/64 inches, so there are no pressure vessels 0.5 mm thick.
Second comment. Brazil is a metric country, but for reasons too long to explain now pipes, shapes and plates are made, calculated and used in inches, like in the USA. Regular plate sizes rolled here by steel mills are 1/8, 3/16, 1/4, 3/8, 1/2, 5/8, 3/4, 7/8, 1, 1.1/4 and 1.1/2.
Third comment. Let's suppose that I'm calculating a pressure vessel. Corrosion allowance is zero. The calculations end to a thickness of 0.69 inches. 0.69 inches is not a regular size. The next upper thickness is 0.75 or 3/4 inches. Of course, I'll chose a plate 3/4 inches thick. The extra, not needed thickness is due to the fact that the calculated thickness fell between two regular sizes, and I must select the upper one.
Now, let's suppose that the vessel has a corrosion allowance of 1/8 or 0.125 inches. 0.69 (uncorroded) + 0.125 (corrosion allowance) = 0.815 inches. The 3/4 inches plate is not suitable any more, and I must go to a 7/8, or 0.875 plate.
Hi Joey
I think this is a matter of definitions. The general definition for a corrosion allowance is the thickness that the designer has allowed for degradation during the life of the vessel. So, typically for carbon steel vessels this may be 3mm. As you mentioned, due to real world economics, different components may have more "thickness above minimum design thickness required" than the corrosion allowance, but you would not say that the corrosion allowance is 3.6mm for the shell, 4.2mm for nozzle A, 6.6mm for nozzle B, 3.1mm for the knuckle of the heads, 7.2mm for the flange of the heads etc.. The CA is given as 3mm, because that is what the designer has alloted for corrosion during the design life of the vessel. That is the "definition" of corrosion allowance.
If the corrosion at some stage exceeds the 3mm allowed, then the designers will again look at the minimum thickness required for pressure retention (and other stresses) and specify this thickness as the minimum thickness for the particular component (e.g. a small bore nozzle) thus allowing further use of the vessel without repair.
Getting back to the original issue regarding the zero CA. This is what the designer has allowed for corrosion, (Nothing) because s/he does not expect any general corrosion mechanism to operate on the vessel. Obviously some of the individual vessel components will be thicker than the minimum design thickness required, but that does not automatically change the corrosion allowance.
Niekie
