Is there anywhere in the code that specifies the accuracy of the hydrotest gauge? I don't mean the range where the gauge is most accurate but how "sensitive" (+ or - X%) must the gauge be? If you are doing a 350 PSI hydro (random #) must the gauge be accurate to .5 #, 1#, 5#, etc.)? It is understood that a calibrated gauge is used.
