The majority of ASME material standards are identical with ASTM ones.
The ones that are not, are nevertheless based on ASTM standards, being somewhat stricter than ASTM.
Marty is of course right. Keep in mind, SA 'IS' Boiler Code, and has nothing to do with the piping codes. And even in boiler code you can use ASTM's you just have to make sure the edition of the the ASTM has been approved. Not only that, take Section VIII for example, non pressure retaining materials only need be weldable.
