We always have our fitters try to keep their tacks out of the bevel as much as possible because generally the welder doesn't want to risk dropping a UT test because of someone elses tack that may or may not be 100%.
My intrepretation was that since the tack weld qualification was a fillet weld vs a CJP weld, then no the tack welder qualification does not allow a tack weld to be placed in the bevel of the joint unless the guy placing the tack their has a CJP certification. Which is another reason why we try to keep the fitters from tacking in the bevel if they are only tack qualified.
Yes it does happen on occasion and I don't worry about but as a common rule of thumb we avoid it. If the tacks are outside the bevel no problem.
Keep in mind the siesmic code requires the same welder to tack weld his test plates as well as weld them.
I'm curious as to others opinion.
