Hi Firefly
ASME IX is only going to give information on NDT tests and acceptance criteria for tests called by ASME IX. LPI is included because it is a required test for weld overlay WPS qualification. I am not aware of a requirement for MPI anywhere in ASME IX, so is not addressed. (As far as I know.) Keep in mind that the LPI acceptance criteria given is not necessarily relevant for let us say a butt weld.
I would say that the best bet for tests not specified in ASME IX, is to use acceptance criteria from the fabrication code that you will need to meet on the job. Another alternative is that the client specification may contain acceptance criteria.
Niekie
