Hi Shane
Thanks for pointing me to this interpretation. The new versions of D1.1 do not have Subsection 5.1.3, so could not get the context of this interpretation. (The oldest version I have is 1998, and even there, this subsection does not exist.) None the less, I think it is clear enough to at least allow somebody else to give me the "benefit of the doubt" in this argument. Is there anybody out there with a 1984 version of D1.1? Mind posting subsection 5.1.3 here?
At any rate, my justification to combining PQR's, or using only one process from a multi-process PQR, was always based on section 3.6.1, (I will attach it to the bottom of the post.) but arguably this does not necessarily allow the mixing and matching (or deletion of a process) in ONLY PQR's qualified to section 4 of the code, but an exercise in logic generally leads people to the conclusion that it should also be equally applicable to PQR's qualified in terms of section 4.
Thanks for that. - Another piece of ammo for the fight!
Niekie
