First, if you are a Third Party Inspector, you should voice your concerns to the Engineer of Record, then the Customer. If you have a chain of command specified in your contract you should use it. You had better have good reasons for your suspicions. Could you call the testing lab that performed the mechanical tests and confirm the test date on the test numbers?
