When you're filling out a welder qual per Sec IX, one of the variables is filler metal deposited. Say a welder qualifies on a piece of 10g stainless steel .135" thick. He roots it, fills it, and caps it in one pass. Do you only put the thickness of the base material for filler metal deposited or do you include the root and cap reinforcement + the base material thickness? I only put the base material thickness because that's you usually qualify to other standards so I interpreted it that way. Always wondered that and I don't want to short change a welder.
Thanks,
Kix
