Nice how close are you to golden, co? There is a shop there called performance car and truck. I think he might've changed it to Maxtorq Performance tho. There number is (303) 278-8038. His name is Rob Watkins he might have a line on one. Good luck
Thanks, I will keep the number. I think I found a guy in Denver that can build a 350 horse for around 5200. I guess I need to find a builder, and that shouldn't be too hard.
Is that 4x4? I used to see a lot of those around stephenville, Texas with cummins in them. Check on craigslist, I saw a complete wrecked 98 on there the other day for $3000.
As I posted this, I bought a wrecked 04 duramax for a grand. The gears are now turning......but I think it will be a monumental task converting this truck to a max. So......I have a max for sale, minus the allison
Do you know a Trevor Allen?
The guy in golden know a Trevor Allen and he thought yall might know each other since he works out in the same area as you I believe?
Hey Sourdough call Will Hall over here in Loma, they swap the 12 valves all the time. Ryan is his son and mechanic built his cummins up to crankin over 700 hp, if I heard right they are building another cummins thats gonna crank out 1200 hp. I would give em a call, besides they are close. Will Hall shop number is 970-858-1125. My name is Jess, I'm the grounds manager there at Country Jam in Mack.
Thanks a bunch for the info. That's what I was lookin for.......
