Up Topic Welding Industry / General Welding Discussion / Rust specks on my vantage
- - By tigrooter (**) Date 03-14-2012 17:48
Got some rust specks on my vantage guess it's from grinding spray. So question is what's the vantage users out there using to buff them out?
Parent - - By Cactusthewelder (*****) Date 03-14-2012 20:16
Emory cloth or stainles steel wool works like a charm
Parent - By 99205 (***) Date 03-15-2012 00:13
The stainless shop I worked at for awhile, would use scotch brite pad and windex, for stainless that has a grain to it.
Parent - - By empire welding (**) Date 03-15-2012 00:08
I cleaned the one I had welding single hand with mild stainless steel sink cleaner from the grocery store.  Worked good, you don't need to scrub hard (just lightly) on the polished pieces but you make a paste out of it and apply it with a sponge and let it sit for a minute then rinse it off.  Looks good as new.  Just how I did it.
Parent - - By Dualie (***) Date 03-15-2012 03:51
what about the rust streaks from the steel captured nuts that Lincoln uses?
Parent - - By tigrooter (**) Date 03-15-2012 15:19
I am replacing them with stainless this weekend. You'd think they would be stainless from the factory
Parent - - By Dualie (***) Date 03-16-2012 07:59
where are you sourcing the correct stainless captured nuts?
Parent - - By tigrooter (**) Date 03-17-2012 01:19
Got a place in Shreveport that's a nut and bolt supply it's all they sell.
Parent - By Dualie (***) Date 03-19-2012 06:41
can you post a phone number and a part number?
Parent - By DaveBoyer (*****) Date 03-16-2012 03:01
There is a scrubbing powder called "Bar Keeper's Friend" that works great on stainless.
If the surface is abrasive brushed, stay WITH the grain.
Scotchbrite and BKF work well on brush finished material, or BKF and a rag for polished stainless.
