Forum AWS Website Help Search Register Login
Up Topic Welding Industry / Welding Fundamentals / best mig welding settings
- - By KennyCalJr (*) Date 03-18-2012 03:39
Does anyone have a good idea on what settings i should use::??  thank you
18 gauge material
Gas: 75 /25
Voltage:?
Amps:?
Arc Control:? that's what the machine i use has.
Wire Feed Speed:?
thank you
Parent - By Lawrence (*****) Date 03-18-2012 12:09
Kenny
You have asked this same question on 4 different threads... What in blazes is wrong with you?
Go try the parameters you have been given and stop being obnoxious.
Parent - By chicagolou Date 03-22-2012 00:23
what position?  I'd start about 15.7 volts, wire speed about 180 - 190.    .035 wire    C25 @ 20-25 cfh.  (Wire speed controls amps.)  Arc control - sounds like its a multi-process machine.  Also depends on position.   But at least a starting point.
