Sa-240 has to also comply with SA-480 Specification for General Requirements for Flat Rolled Stainless and Heat Resisting Steel Plate, Sheet, and Strip".
I think your position with the supplier should be that the material has to comply with the Workmanship section of SA480. From SA480- "The steel shall have no imperfections of a nature or degree for the type and quality ordered that will adversely affect the stamping, forming, machining, or fabrication of finished parts."
