Up Topic Welding Industry / Technical Discussions / Is 3/16" sheet fillet welded to 1/2" base prequalified?
- - By dwestphal Date 03-20-2012 21:53 Edited 03-20-2012 23:06
AWS D1.1 is for 1/8" and thicker
AWS D1.3 is for 3/16" and thinner
Is there a prequalified joint figure for fillet welding a HSS (square tube ASTM A500 Gr B) that has 3/16 inch walls to a base plate (ASTM A36) that is 1/2" thick?
Thanks in advance!
Parent - - By Lawrence (*****) Date 03-20-2012 23:26
Look at D1.1
Clause  3.9 (1)
and
Table 3.1
Parent - By 803056 (*****) Date 03-21-2012 03:06
It can be prequalified if all the conditions of Clause 3 are met.
