Up Topic Welding Industry / General Welding Discussion / Fracture Critical Member Welding and S84 Supp. Requirement
- - By eekpod (****) Date 03-23-2012 13:38
Is anyone familier with Supplemental Requirement S84 that is referenced in my AREMA code for steel structures?
Yes this is for a fracture critical weldment.
I've been through it 3x now and can't find it.  I also went through ASTM A709 nothing there. I went through the A673 CVN spec as well as A6 and can't find it.
Any help owuld be appreciated, thanks
Parent - - By eekpod (****) Date 03-23-2012 19:32
darn....
I was hoping to have an answer by now:fat:
Parent - - By eekpod (****) Date 03-26-2012 15:52
Follow up in case anyone else needs it.
The S84 is an old referance from AREMA.  The 2009 edition has it in it but not the newer edition, it was changed to a table 8 or table 9.
Also because I had the newer ASTM specs that had already been changed from S84 to the table that's why I coulnd't find it.
So be sure you are using the correct and latest editions of the specs and they should match up.
Why do I feel like I'm talking to myself? :wink:
Parent - By DaveBoyer (*****) Date 03-27-2012 00:57
You asked if anyone was familliar with it, and I guess none of Us are.
