I'm not real sure what your question is,...but I'm going to take a shot at it....
If you are asking about whether to use 14db or 19db over your reference level to scan, then look at Table 6.2 or Table 6.3 depending on if it is statically loaded or or cyclically loaded, and note the length of your soundpath and use the chart at the bottom right of each of those tables to set your scanning db.
If this isn't your question, then ask again and I will try to help where I can.
