It is not recommended to weld CA6NM without PWHT. There will be untempered (brittle) martensite in the HAZ of the weld no matter what filler metal you use. If pipe is subsequently welded to a CA6NM casting, often the casting is overlayed with 309L and then gets a PWHT. Later, the pipe can be welded to the overlayed portion of the casting without further PWHT. Another option is to use local PWHT with resitance heating pads.
