The welding sequence I suggest is described below.
Let's suppose that the flange is in position and ready to start welding. No, I don't suggest to bevel the flange, its cross sectional area is rectangular. What you should bevel is the pipe. The flange has two faces, one around the pipe end and the other one around the pipe wall.
We'll call the first one "the pipe end face"and the other one "the pipe wall face". 36 inches is nearly one meter, a sufficient distance for two welders to work at the same time.
1. The two welders, working at the same time on the pipe end face, will apply two weld beads say 2 inches long, one on the 12 o'clock and the other one on the 6 o'clock position.
2. Then, working at the same time on the pipe wall face, will apply two welds beads 2 inches long, one on the 3 o'clock and the other one on the 9 o'clock position.
3. Next, they will apply two 2 inches long beads on the pipe end face, one between the 1 and 2 o'clock position and the other one between the 7 and 8 o'clock position.
4. The next two 2 inches long weld beads will be applied on the pipe wall face, one between the 10 and 11 o'clock position and the other one between the 4 and 5 o'clock position.
5. At this time, the welds described on paragraph 1 have cooled down, so the welders will apply two beads on the same o'clock positions, but on the pipe wall face.
6. Also at this time the welds described on paragraph 2 have cooled down, so the welders will apply two beads on the same o'clock positions, but on the pipe end face.
Well, you have surely understood the rest of the sequence, so I don't have to explain it. Of course, cleanliness of the welds is a thing that deserves careful attention.
Tell me how you did on.
