Up Topic Welders and Inspectors / Welding Equipment Classifieds / welder sa200 1968 1500 hrs 3500 obo phoenix az
- - By pipelinner2007 Date 04-22-2012 22:43 Edited 08-02-2012 16:41
68 blackface f163 sa 200  code 8023/6791 s/n A873707 1500 hrs rebuilt  all copper has all the up grades you can get does not use a drop of oil or water changed oil every 50 hrs
electonic distriburtor murfy gauges spin on oil fitter and spare parts elect ideler 8 blade fan quick change oil plug 2 stage paper air filter extra set of brushes extra alternator &  starter  2 cable remote boxs one new  zenith carb pigtail for remote electronic idler weldmart muffler hour metor case of oil filters extra set ingition parts new paint is fair to good would repaint have all paper work LOAD BANK WAS 293 i was told this is a 68 motor & gen  in a 79 frame. 2remote boxs 100 ft corh cable remote and new brushs all spare starert and altnator quick oil chang plug 6 blade fan
602 274 3605 or 602 390 4108  price  3500
sold
Attachment: leftview.JPG (398k)
Attachment: rightview.JPG (456k)
Attachment: closeup.JPG (619k)
Attachment: longview.JPG (688k)
Attachment: long1.JPG (605k)
Parent - - By dogweld (***) Date 04-23-2012 00:57
in 68 they where redface not blackface
Parent - By 64 red L Date 04-24-2012 23:58
it has an octagon barrel cant be a rad face
Parent - By tnhnt (***) Date 04-23-2012 03:42
Can you send photos?
Parent - By 52lincoln (***) Date 04-25-2012 04:24
man thats a newer welder then a 78.its like a 80's or early 90's model.probably a good machine just saying its a little off on the yr model
Parent - By KSellon (****) Date 04-27-2012 13:38
Our shop did rebuild this in July 2007, we married 2 machines together. Don't know about its life since then.
ARMATURES AND COILS HAVE BEEN OHMED. REBUILT ENGINE TO INCLUDE: EXHAUST VALVES, GUIDES, SPRING SHIMS, PISTONS, RINGS, ROD BEARINGS, MAIN BEARINGS, CAM BEARINGS, PIN BUSHINGS, HEAD SET, FRONT END AND OIL PAN SET, OIL PUMP, SPEED SLEEVE, FREEZE PLUG KIT, AND TIMING SET. VALVE JOBBORE BLOCK 020, GRIND CRANK 010-010, RECON RODS, RESURFACE HEAD AND MANIFOLD. SAFETY GAUGE AND HOUR METER INSTALLATION. REMOTE CONTROL PIGTAIL INSTALLATION. REPLACED DISTRIBUTOR WITH ELECTRONIC IGNITION. REPLACE OIL BATH WITH K & N BUT SHIP OIL BATH WITH MACHINE TO CUSTOMER. EXTRA BRUSH SET AND CABLE LUGS PROVIDED FOR CUSTOMER. LOAD AND WELD TESTED. CHECKED OCV AND OUTPUT.
- By Belba (**) Date 04-25-2012 04:46
It's definately not a '68 or a red face it's a 1978-1979 black face.
