Up Topic Welding Industry / General Welding Discussion / Annealing Stainless tubing.
- - By awill4wd (**) Date 01-05-2003 00:08
Can anyone on the list help with some info on annealing grade 304 stainless tubing? We have a couple of little jobs where we require some tight bends in 1/2" tubing and I'm after an "in shop" method to anneal the tubes.
Any info would be appreciated.
Regards Andrew.
Parent - - By George-kh (**) Date 01-15-2003 10:32
I don’t know why you want to anneal stainless steel.
It’s not common to do that. In some cases may stress relieving annealing in relatively low temperature and long time comparing to carbon steel.
Roughly saying heating of stainless steel between 400C to 800C cause chromium carbides that weaken corrosion resistance.
Parent - By G.S.Crisi (****) Date 01-16-2003 14:31
Agree with George
Parent - By jon20013 (*****) Date 01-15-2003 11:07
AWS D10.9 Annex should contain all the information you need.
