You mean the 50 amp plug on the welder?If thats it just plug in to your 30 amp sevice .You could change the plug to match the 30 amp one.I think its a waste of time.All the welders have that style plug.Some that draw more than 50 amps.I think thats what you meant?Sounds like you like you new welder.Heavy little sucker.Its got lots of copper in it.I like that part of the welder,but not moving it.
From a practical point of view there is no real problem with a 50 amp receptical served by a 30 amp breaker. If something tries to draw 50 amps the breaker opens as it should and there is no danger. The danger is the other way- say a device that normally draws 15 amps is plugged into a circuit served by a 30 amp breaker and thru some fault in the device it begins to draw 25 amps, the 30 amp breaker is unaware of any problem but the device is unlikely to be able to dissipate the extra energy and is likely to catch fire. The electrical code allows only a small oversize for breakers serving dedicated circuits (I don't remember how much but guess it would ask for a 25 amp breaker in this case). The code may also have something to say about oversized recepticals. I'm not an electrician so I don't keep the code memorized. Perhaps someone who actually is an electrician will fill this out.
I've seen most of your posts, replied to some, and I believe what you were really asking for was a machine that actually worked. I'm not familiar with this particular machine but I'm betting it does a fine job for you.
Best of luck with it-
Bill
