Up Topic American Welding Society Services / Certifications / Prequalified material thickness for flare bevel groove
- - By KWoockman Date 04-27-2012 22:18
If I am reading D1.1 right a GMAW single flare bevel groove in 1/8" material will not fall into the Prequalified criteria because the Prequalified PJP groove joint details in Figure 3.3 clearly states 3/16" material min. I am looking for someone to disagree with me because I find this as odd, most of the minimum material thicknesses qualified in section 4 is 1/8” material. I would like to hear your thoughts.
Parent - - By TimGary (****) Date 04-28-2012 00:04
You can find prequalified procedures for flare bevel and other groove profiles, for materials 3/16" and below, in the AWS D1.3 sheet metal code.
Tim
Parent - By KWoockman Date 04-30-2012 15:37
Hi Tim,
  Thank you for the reply, however the contract and fabrication documents specify the use of D1.1 only therefore I cannot deviate from there. Thanks again!
Kevin
Parent - - By MBSims (****) Date 04-28-2012 12:20
Perhaps it is because there is such a small radius on 1/8" wall tube that it is considered to be a fillet weld?
Parent - - By 803056 (*****) Date 04-29-2012 17:45
I could be wrong, but I put my money on a concern related to burn through. Prequalified GMAW is either spray or globular transfer; too hot for thinner material when welding flare bevel or flare vee grooves.
Parent - By KWoockman Date 04-30-2012 15:48
Hi Al,
  The weld is a .125” X .125" tack weld that holds some expanded metal in place to an 11 GA. formed channel so I do plan on staying out of short arc. Thank you for the reply.
Kevin
Parent - By MBSims (****) Date 05-01-2012 01:31
A good answer as well, and probably closer to what the line of thinking was.
Parent - - By WeldinFool (**) Date 04-30-2012 15:14
Yup, AWS D1.3 is what you want.
Parent - By KWoockman Date 04-30-2012 15:38
Hi WeldinFool,
Kevin
