Up Topic American Welding Society Services / Technical Standards & Publications / Tubular Struc.- 6G & 6GR PQR Qualification-AWS D1.1 2010
- - By Nalla (***) Date 05-05-2012 02:37
Dear Friends
Appreciate detail guide
Applicable Code- AWS D1.1 ED 2010
Base material - Group II - API 5L Grade X52 X 8" sch 120 ( CVN requirement min. minus 40 deg. )
Joint Configuration - Single V with  ( permanent metallic Backing Strip - 38mm[width)] x 6mm[thk]).
Root Gap - 4 ~ 6mm
Proposed Weld Process -
A - Root- SMAW / Hot/Fill/Cap- FCAW
B - Only 1 process - SMAW
C - Only 1 process - FCAW
Proposed Test Position - one coupon in 6G and one in 6GR position
Queries
1) This PQR qualification range based on Table 4.10 & Note c. ( Weld Process - Test Coupon A,B,C ).
2) Deposited Weld Thickness qualified range ( Weld Process - Test Coupon A ).
Thanks
Parent - - By 99205 (***) Date 05-05-2012 05:14
:confused:
Parent - - By Shane Feder (****) Date 05-05-2012 12:48
I second that 99205
Parent - - By 46.00 (****) Date 05-05-2012 12:54
:confused:Third it!!??
Parent - - By Nalla (***) Date 05-05-2012 13:42
Dear Sirs
Pls advise if you cannot understand my queries?
Thanks
Parent - By 46.00 (****) Date 05-05-2012 17:16 Edited 05-06-2012 02:00
Hi Nalla!
I cannot understand your question.
Parent - By welderbrent (*****) Date 05-06-2012 00:29
See now, that is probably how we should handle many a thread that sometimes sits here and doesn't get any response because either no one who knows about the content has checked in or no one wants to step out and respond or, as in this case,
NALLA, we don't understand the query.
Instead of keeping quiet we should say so.  But that may make us look stupid.  So, we don't do anything and frustrate the OP.
Oh well, off of my sidebar soapbox.  No, I have to admit, I don't understand your query.  Can you try to explain it further for us?
Have a Great Day,  Brent
Parent - By MBSims (****) Date 05-06-2012 14:28
"Queries
2) Deposited Weld Thickness qualified range ( Weld Process - Test Coupon A )."
The above appears to be the questions.  I don't have my D1.1 book here at home to see what it says about this.
Parent - - By MBSims (****) Date 05-05-2012 13:56
Is there a question in there somewhere? I missed it.
Parent - By Nalla (***) Date 05-08-2012 13:45
Dear Experts
Item 1 & 2 are the queries require your guidance
Thanks
