We are having an issue at work with metal backing. D1.1 clearly states that the metal backing will be continuous (meaning welded together if needed)for the full length of the weld.
D1.6 states that when "fused metal backing is used", it will be for the entire length of the weld. The question is, what are they calling "fused metal backing"?
Some of us say it is the same as in D1.1 - welded together (CJP), but our supervisor says it can be butted together and not welded, even though it is a stainless CJP weld.
He says the "fused metal backing" refers to the backing being fused to the base metal during the welding process. It doesn't seem that D1.1 would have one requirement
for metal backing, and D1.6 another. The new Welding Manager also interprets it to mean that the backing bars can be butted together and not welded to each other.
Which is it?
