Up Topic Welders and Inspectors / Welding Equipment Classifieds / Weld Fault samples
- - By sriley77 (*) Date 05-18-2012 13:36
I'm looking for a set of weld fault samples. Hoping to find some fairly cheap. New goes for around $600, my current budget doesn't allow for that.
Thank you,
Scott
Parent - By jwright650 (*****) Date 05-18-2012 13:48
You can make your own, then map out the defects/indications....that is what I did when I was teaching some guys here at work to UT.
