Up Topic Welding Industry / ASME Codes / ASTM A519 GR.4130; PSL-3 G ; NACE MR-01-75-PQR Qualification
- - By Nalla (***) Date 05-30-2012 10:05
Dear Experts
Appl. Code - ASME Sect IX,2010
Weld Process - GTAW / SMAW . Position - 6G
Mat- 6.75OD x 0.875" sch.
Need advise on -
1- Suitable consumable in KOBE / ESAB Brands
2- Heat Input Control
3- PWHT Requirement / Range
Thanks
Parent - - By Duke (***) Date 05-31-2012 03:21
Materials?
Parent - By Nalla (***) Date 05-31-2012 13:14
Duke
ASTM A519 GR.4130- Piping
Parent - By welderbrent (*****) Date 05-31-2012 14:40
Duke,
Not to be picky... he had it in the thread title.
Have a Great Day,  Brent
Parent - - By Firefly (*) Date 06-04-2012 14:48
Nalla, answers to your questions based on my experience:
1. Use ER80S-D2 or ER100S-G for GTAW and E10018-D2 for SMAW.  All welding cons must contain less than 1% nickel in order to comply with nace.
2. Use 1 - 1.5 kj/mm HI. Use 200 deg C min preheat with 350 deg C max interpass temp.
3. PWHT at 640 - 650 deg C for 2 to 4 hours soak time to achieve nace hardness requirements in the haz and weld metal.
Rgds
Parent - - By Nalla (***) Date 08-25-2012 23:58 Edited 08-26-2012 00:21
Dear Firefly
How you have decided on Preheat & Interpass Temperature and ref. ASME Code Section
Customer Spec. Require - Max Hardness-22HRC & Min Tensile Strength- 105000MPa
Thanks
Parent - - By Firefly (*) Date 08-27-2012 14:25
Nalla. My recommendations are based on my experience in the oil and gas industry. I usually work in accordance with API 6A which refers back to ASME IX. You probably mean 105000 psi min tensile strength. I think you should go with the ER100S-G for the GTAW wire (instead of the ER80S-D2) to give you a little more strength in the root. Rgds
Parent - By Nalla (***) Date 08-28-2012 13:10
Dear Firefly
I'm still waiting Metrode Test Run Data Record.
Hope by next week can proceed with PQR Qualification
Thanks
