That is true to a limited extent.
The issue is when dissimilar metals are joined and when different filler metal compositions come into play. An example of what I have encountered would be when working with the aluminum alloys. For example: welding 6061-T6, everyone's favorite alloy. The engineer can use several different filler metals, each with specific mechanical and chemical properties. The mechanical properties govern, i.e., the weld usually out performs the base metal, but that isn't always the case when joining different aluminum alloys to the 6061-T6.
One welding standard I used to use when welding aluminum alloys required a chemical analysis of the weld. Changing groove details changed the chemistry and it also affected the properties of the weld, i.e., the strength of the joint. It was a dilution issue. Any changes in the filler metal selection or groove detail required a new PQR to demonstrate the combination provided the properties required. It made sense then and it still makes sense to me now. I find it interesting that the chemistry issue has fallen by the wayside. New people, new opinions. Not that I find the new opinions are always correct. This is one case where the chemistry made a difference in the ability of the joint to function as intended. What works with a V-groove does not necessarily work with a single pass square groove.
I believe one of my good friends says it best when he refers to Aluminum as "almost a metal".
I blame it all on the ASME influence.
