Hi Craig;
Sorry I don't have any more info for you, but I can suggest you use a filler metal of at least 90,000 tensile strength. an ER90S-xx or higher. As for the pre-heats, I don't have a clue, my guess is that the tubing isn't very thick, maybe a 1/16"? I kinda doubt you'll need to pre-heat, but I sure would try welding some cut off scrap first and see what happens. I couldn't find anything in D1.1 2002 on that mat. none of the ASTM numbers match. Maybe someone out there can be of more assistance.
Rick
