Up Topic Welding Industry / Inspection & Qualification / fillets on bevel welds
- - By russd Date 06-06-2012 12:16
This  is my first time on forum and i would like to know how a fillet weld is measured when it is on a bevel weld. Is leg height measured from the base metal or from the reinforcement on the bevel weld. Thanks for the help, russd
Parent - By jwright650 (*****) Date 06-06-2012 12:23
Hi Russ,
You measure the reinforcing fillet weld the same way you would do any other fillet weld, from the base metal. Welcome to the forum.
Parent - - By welderbrent (*****) Date 06-06-2012 13:17
Russ,
As John said, basically, when measuring the fillet weld over a bevel weld you ignore any idea that the bevel weld is there and just measure the fillet weld as you would any other fillet weld.
Now, if the groove weld in the bevel was not full enough and it is actually wider than the leg measurement called for on the fillet weld then you have an underfill condition that will in many ways make the fillet weld larger in order to make it right.  But if the groove weld was properly finished in the first place then, while you will see the weld in the bevel joint, the fillet can be sized as called out on the plans and per proper fillet weld gage usage.
Have a Great Day,  Brent
Parent - By 803056 (*****) Date 06-06-2012 16:45
Keep in mind that the existing fillet weld is not cause for rejection even if a reinforcing fillet weld is not specified when working to the D1.1 requirements.
