Up Topic Welding Industry / Technical Discussions / WPS's for pipelines in service??
- - By MKNIK (*) Date 06-11-2012 23:02
Hi all.
Someone could clarify this issue;
Application is correct weld with SMAW process with ASME WPS performed under oil pipelines in service, supported with the recommendations API 2201? Since we saw API 1104 APPENDIX B WELDING IN SERVICE.
Parent - - By 3.2 Inspector (***) Date 06-13-2012 01:28
Yes.
Which issue?
Parent - - By MKNIK (*) Date 06-13-2012 05:21
hello inspector,  thank you for atention me
sorry for my english bad.
Concerning the previous post;
Service pipes in wall thickness are higher than ¼ ", API 1104 Appendix B focuses on wall thickness less than ¼".  is correct use of a WPS performed under ASME, with low hydrogen electrodes?
Parent - - By 803056 (*****) Date 06-18-2012 10:39
If the pipe is in-service and it is used for the transportation of petroleum products, API 1104 Appendix B is the guide you should follow.
The WPS and the welder must be qualified using the apparatuses described and depicted in Appendix B to simulate the effects of rapid cooling on the weld and HAZ and to demonstrate the welder will not burn a hole through the line pipe wall.
Parent - - By MKNIK (*) Date 06-23-2012 14:29
HELLO
WE ALSO APPLY API 1104 APPENDIX B IN PIPES IN SERVICE WITH A WALL THICKNESS GREATER THAN 1/4 "??Thank you for your help and patience
Parent - By jarsanb (***) Date 06-27-2012 13:49
If that is a question you are requesting an answer to...I would say yes. API 1104 appendix B should be applied to all thickness that are in-service. The 1/4" that you refer to is applied to burn through potential. Hydrogen cracking, which is the other main concern, also needs to be addressed.
