Hello all, I need some assistance on group numbers.
If a group number on a WPS says group 1 to group 1, that means the material located under group 1 can be joined to other group 1 materials. What if A 36 material that is less than 3/4 in thick is welded to material more than 3/4 in thick, then should the WPS read group 1 to group 2? I believe the anwser is yes. I guess what I'm trying to get to is, how should it be worded on a WPS if A 36 material less than 3/4 in. is welded to material that is more than 3/4 in. and then for the same WPS to able to weld group 1 to group 1 and group 2 to group 2 and group 1 to group 2 and vice versa in case af varying thicknesses or same thicknesses.
How would it read on the WPS?
Group 1 to Group 2
Group 1 & 2 to Group 1 & 2
Thanks,
