Dear all,
my client want to run a PQR for the material 2-25 Cr -1.0Mo to Inconel 601 using welding process GTAW and SMAW .
my query is, prior to commencement welding does it need a preheat ?
The actual thickness of 2.25 Cr material for production is 250 mm to be welded to Inconel pipe with partial penetration.
Any advice would be appreciated.
thank you
Ladies and Gentlemen,
I suggest contacting the www.aws.org engineers at (305) 443-5951 Fax or with an e-mail, the consumable manufacturer i.e. Lincoln, the Inconel manufacturer and be careful. If it was my "situation" I would have delayed cracking concerns and fatigue life concerns. I hope this helpful.
Sincerely
Len Andersen weld@spemail.org
914-536-7101 , 212-839-6599 8-4 New York Time , 914-237-7689 (H) www.lenandersen.com
