All the D1.1 prequalified joint details for single bevel groove welds (B-U4a for example) when shown in the horizontal position, have the beveled side on top. The top plate is always shown beveled, the bottom plate is always flat, with no bevel.
I realize the joint is allowed for all position welding. But my question is when in the horizontal position, if the joint is prepared upside down as shown, with the bevel angled down instead of up, and the top plate is flat with no bevel, ..is the joint still prequalified?
thnx
By 803056
Date 07-06-2012 14:08
Edited 07-06-2012 14:46
I'm not sure what your level of involvement in this operation, but there is an issue that should be given careful consideration.
Lamelar tearing in the thicker member is a potential problem with the joint configuration as detailed. Since this is posted under the heading of D1, I assume it safe to say you are working with AWS D1.1 if you are welding carbon or high strength low alloy steel. That being the case, due consideration to the cautionary comments of clause 2.7.3 and C2.7.3 (D1.1-2010) should be reviewed.
