Yes,
but I would advise you to create the WPS using tighter variables than D1.1 allows (maybe not put the entire +/-7% range for Volts or +/-10% for current/WFS). Then take the WPS that you have written and test the range of variable on it (fillet, etch test). You want to insure that the automated system set anywhere within those ranges gives you the result you're looking for. Insure your programmer understands the range.
If your operator has the ability to make any type of adjustment to the program then qualify them per Fig. 4.22 or Fig. 4.37 as applicable.
I would also consider giving your programmer a Welder Qualification test. He/She should understand what is nessesary to make sound welds and have the ability to do so.
PWC
