Hi, Sect. IX, QW-200.4 states that "When following a WPS that has more than one welding process, filler metal, or set of variables, each process, filler metal, or set of variables may be used individually or in different combinations ...." So, yes, you may use just the SMAW process. (although, I don't understand the comment that TIG is qualified from 0-8mm and SMAW from 1.5-9mm). Under section IX, the base metal for 9.27mm would be qualified for groove welds 1.5 - 18.54mm. The TIG process deposit thickness would be qualified for groove welds up to 2t (PQR TIG deposit thickness) with no minimum, and likewise with the SMAW process. The sum of the qualified TIG deposit and SMAW deposit to be listed individually on the WPS for groove welds should add up to 18.54 mm.
Regards, Sol
