If you are working to ASME Section IX, what construction code are you using?
In general, you have to qualify the WPS. ASME only permits a few AWS SWPSs to be purchased for use by a contractor.
Check Section IX, Article V to learn what you can and can't do with regards to using SWPSs purchased from AWS.
