Up Topic Welding Industry / Technical Discussions / AWS D18.1 qualification
- - By patriot (*) Date 07-23-2012 18:03
Does anyone know the qualification range when testing welders for sanitary stainless piping under AWS D18.1?  Piping is .065" wall and welding from 1" to 4" diameter.  Is it like ASME Section IX where I believe 2" diameter will quality from 1" to unlimited?  And is there a prequalified WPS that can be used?
Parent - By TAC (*) Date 07-23-2012 19:05
The answers you seek are in AWS B2.1.
You will have to qualify the procedure.
