When working with AWS D1.1, when a welder qualifies on a grooved joint with backing, he/she is qualified for single groove welds welded from one side with backing, double CJP groove welds if the second side is back gouged before welding the second side, partial joint penetration groove welds, and fillet welds.
Hello Travis,
The fast and simple answer to your question is: Yes, a welder who qualifies on a CJP with backing is qualified to weld CJP joints/welds that are backgouged and welded from the second side.
Now, to see if we can clear up the confusion:
1) Table 4.12 is not connected to the qualifications of a welder from Clause 4.24 and Table 4.10 (note Table 4.10).
2) Table 4.12(6) is in reference to welding qualified with a PQR (WPQR testing) NOT a standard Welding Qualification test under 4.24, Table 4.10 and Figures 4.21, 31, and/or 33.
3)So, if a Procedure is Qualified with a backing bar then the elimination of the backing bar would require a new procedure to be qualified according to Clause 4.23 with Table 4.12.
**Notice the note above the list of Variables Requiring Requalification: "Essential Variable Changes to WPQR Requiring Requalification"** (emphasis mine)
4)This would indicate that due to material, process used, filler material, or some other factor they had to qualify a procedure and were not able to use a Pre-Approved Procedure which would only require the development of a WPS and welder certification.
Hope I cleared up the usage. If not, someone will come along with more help and to rebuff me for any errors.
Have a Great Day, Brent
edit: see, Al beat me to it.
