Dear Experts
Appreciate if welding gurus, share your experience on correct weld sequence.
Weld Process - FCAW , SAW.
Offcourse these processess require Rub-on / Run-off Tabs to initiate,Stablise and acheive complete butt weld.
Advise on correct welding sequence, typically for butt weld joints>> +-joint , T-joint, Seam with radius , Joints with multipleT-Joints ,Radius & seams.
Also advise right technique on start/stop and terminations of the butt welds ends.
I always belive all weld must start form Run-on Tab.
Pls refer attached -Typically practised in my workshop
Thanks
