Well....that depends. You are allowed to butter one or more of the welding faces to achieve a closer root opening, but this all needs to be done ahead of welding out the joint. You may need to speak with the EOR about your root opening, it will end up being his call if it is excessive. See Figure 5.3(B) and Clause 5.22.4.1 in D1.1:2010
