What is good starting point for pricing structural fabrication by the ton? I know the $ amount can vary a lot depending on the the amount of fabrication . I just thinking straight forward fab. Beams and columns. I usually just estimate time and materials when I'm bidding,but I would like to have some standard to go back and compare to just to be sure I'm in the ballpark. Most of the time I am only bidding to supply the fabricated steel and not installation.
Know this is a broad question but any input would be appreciated.
May want to figure the number of manhours per ton, then use your shop's hourly rate.
Yeah.....you're talking about a vast grey area there. You could have all kinds of goodies popping up after you figure things by the ton.....
I agree with the Vast Grey area. You could be taling about welding 2 1000lb plates together with a single fillet weld or 2000lbs of Hinges. GREAT BIG DIFFERENCE
Strother-
You might take a look at Means Estimating free 7 day trial offer. Not neccessarally the best metric for bidding, but a starting point to adjust from and compare national/union/open shop pricing. They tend to use very conservative values which are great to justify and substantiate change orders. Competitive bidding needs a sharper pencil. Free trial allow you to print pricing/man hours/costs for line items of a ton of fabrication values.
Thanks Yojimbo , That is what I'm looking for, just a reference. I've found a few things on line but they were out of date.
